The 2.5" SDD / HDD Mounting Bracket for 3.5 Drive Bay now comes in a convenient 5-pack. This mounting bracket lets you quickly install a 2.5" SSD or HDD into a single 3.5" bay in a desktop PC or server, with no tools required. The tool-less mounting bracket supports a 2.5" solid-state drive or hard drive from 7 mm to 9.5 mm in height.
The mounting bracket's tool-less design makes it fast and easy to install a 2.5" drive in a computer or server, without the need for additional hardware or tools. It's ideal for system administrators and integrators who are building or upgrading a computing solution for a wide range of businesses and organizations, including schools and hospitals, saving valuable time and effort on installation projects.
The lightweight mounting bracket is designed for trouble-free, reliable performance. To install a drive, you simply secure it into the mounting bracket, without using tools. Then, you put the bracket into a 3.5" drive bay in your computer and the bracket holds the drive in place using the tool-less plastic pegs.
- StarTech.com 2.5 SSD/HDD Mounting Bracket for 3.5 Drive Bay - 5 Pack - Tool-less - Hard Drive Mounting Kit (BRACKET125PTP) - storage bay adapter
- Storage bay adapter
- Packaged Quantity
- 5 (specifications are for single item)
- Black
- Supported Form Factor
- 3.5" to 2.5"
- Expansion Bays
- 1 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- Product Material
- Plastic
- 10.2 cm x 15 cm x 1.3 cm
- 33 g
- 2-year warranty
- Packaged Quantity
- 3.5" to 2.5"
- Product Material
- Plastic
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 3.5"
- Included Accessories
- 30 plastic pegs
- Tool-less
- RoHS, WEEE, REACH
- Limited warranty - 2 years
- 10.2 cm
- 15 cm
- 1.3 cm
- 33 g
- Shipping Width
- 15.5 cm
- Shipping Depth
- 9.5 cm
- Shipping Height
- 11 cm
- Shipping Weight
- 40 g
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.44 |
StarTech.com 12in Latching SATA Cable | In Stock | £3.62 |
StarTech.com 18in Latching SATA Cable | In Stock | £4.48 |
StarTech.com 24in Latching SATA Cable | In Stock | £5.98 |
StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit | In Stock | £4.38 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.40 |
StarTech.com 6in Latching SATA Cable | In Stock | £4.98 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com 4x SATA Power Splitter Adapter Cable | In Stock | £6.14 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.52 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £19.64 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £43.44 |
StarTech.com M.2 NGFF to SATA Adapter | In Stock | £23.25 |
StarTech.com CFast/SATA Adapter | In Stock | £22.36 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.40 |
StarTech.com 2.5" SSD/HDD Mounting Bracket | In Stock | £4.49 |
