StarTech.com 5.1 Channel PCI Surround Sound Card Adapter
Quicklinx: 9FSYWS00 Mfr#: PCISOUND5CH2
Interface: PCI
Sound Output Mode: 5.1 channel surround
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£11.25 ex VAT
£13.50 inc VAT
Add 5.1 channel audio to a desktop PC through a PCI slot. The PCISOUND5CH2 PCI Surround Sound Card lets you add 5.1 channel audio to a desktop PC through a PCI slot, giving you audio output, and microphone/line input via 3.5mm mini-jacks.
A cost-effective multimedia solution for delivering high quality surround sound, this PCI sound card lets you enjoy full-duplex, 48KHz/16bit audio playback/recording, and offers support for HRTF 3D positional audio, Microsoft DirectSound, DirectSound 3D, and A3D .
Three internal auxiliary input connectors let you connect your CD drive directly to the sound card. If your drive features external control buttons, the card allows playback without impeding your computers performance.
With support for PCI v2.2 and an included low profile/half-height installation bracket, this sound card is an ideal home theater PC solution that's perfect for your standard or small form factor (SFF) PC.
StarTech.com 5.1 Channel PCI Surround Sound Card Adapter - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI
1.9 cm x 12.1 cm x 12.2 cm
90 g
Signal Processor
CMI-8738 LX
Sound Output Mode
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
Linux 2.6.x, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
Sound card
Internal
Interface Type
PCI
1.9 cm
12.1 cm
12.2 cm
90 g
Processor / Memory
Signal Processor
CMI-8738 LX
Audio Output
Sound Output Mode
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
DirectSound, DirectSound3D, A3D
1 x speakers (rear) - mini-phone stereo 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x audio - 4 pin audio
Low-profile bracket
FCC, RoHS
50 °C
5 - 85%
Interface: PCI
Price Range Ex VAT: 0 - 50
