The VS440HDMI 4x4 HDMI Audio/Video Matrix Switch/Splitter (with Audio and RS232) lets you share up to 4 distinct HDMI or DVI inputs (using HDMI to DVI adapters - not included), with audio, between 4 independent displays or projectors.
Providing convenient front push-button and RS232 PC software control, this matrix switch allows each input and the corresponding audio to be switched individually, meaning that different A/V sources can be shown on each output, or a single source can be output to several offering maximum flexibility.
The switcher features a front panel LCD display for easy status monitoring, plus an included remote control and IR extender module for simple control from a distance.
Designed to provide maximum functionality while saving space, the HDMI Video Matrix Switch can be used as a standalone solution or rack-mounted using ear-mounts (included).
- StarTech.com 4x4 HDMI Matrix Video Switch Splitter with Audio and RS232 - 4x1 HDMI Video Switch - 4 Port HDMI Switcher (VS440HDMI) - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- HDMI
- Power
- AC 120/230 V
- 18.5 cm x 44 cm x 4.2 cm
- 2.4 kg
- Black
- 1-year warranty
- Designed For
- P/N: ST121HDBT20L, ST121HDBT20S, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121SHD50, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Max Resolution
- 1080p
- Max Video Bandwidth
- 225 MHz
- 4 x HDMI input , 4 x HDMI output , 1 x serial (RS-232) DB-9
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Rack Mounting Kit
- Included
- FCC, RoHS
- 18.5 cm
- 44 cm
- 4.2 cm
- 2.4 kg
- Limited warranty - 1 year
- 0 °C
- 70 °C
- 0 - 95%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.28 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.78 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.39 |
StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p | In Stock | £63.65 |
StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p | In Stock | £94.69 |
StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall | In Stock | £1,110.56 |
StarTech.com VGA to HDMI Scaler - 1920x1200 | In Stock | £207.80 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
StarTech.com 4x4 HDMI Matrix Switch w/Audio | In Stock | £560.20 |
