StarTech.com 4x4 HDMI Matrix Switcher / HDMI Extender over Cat5 / Cat6 – 230ft (70m) – 1080p
Quicklinx: 97R7WS00 Mfr#: ST424HDBT
£924.33 ex VAT
£1,109.19 inc VAT
Extend the HDMI signal from your ST424HDBT Matrix switch over Cat5/Cat6 cable, with IR control. This HDBaseT receiver works with the ST424HDBT HDMI matrix switch to extend an HDMI audio/video source up to 230ft (70m) over Cat5e/6 cabling. One STHDBTRX receiver unit is required for each individual remote display.
Together with the ST424HDBT, the CAT5 HDMI receiver works to create a digital signage solution that eliminates the expense and hassle of running multiple devices with an HDMI matrix switch and extender in one clutter-free system. Because the signal is extended using standard Cat5e/6 Ethernet cables with RJ45 connectors, you can use your existing cabling infrastructure, without the additional cost of special cabling or connectors.
For remote source operation, the HDMI receiver can also extend an Infrared signal from a remote control to operate either the display or the video source from either side or system, using the included IR extender and receiver cables.
StarTech.com HDBaseT over CAT5e / CAT6 HDMI Receiver for ST424HDBT - 230ft (70m) - 1080p (STHDBTRX) - video/audio/infrared extender
Video/audio/infrared extender (receiver)
External
Australia, North America, United Kingdom, Europe
Transmission Medium
CAT 5e/6
Max Transfer Distance
70 m
AC 120/230 V
11 cm x 7.5 cm x 2.35 cm
P/N: ST424HDBT, SVA5M3NEUA
External
Wired
Max Resolution
1920 x 1200 / 1080p
70 m
Status Indicators
Port status
1 x HDMI , 1 x IrDA , 1 x network - RJ-45
FCC, RoHS
External power adapter
Installed Qty
1
Max Supported Qty
1
AC 120/230 V
11 cm
7.5 cm
2.35 cm
-5 °C
35 °C
5 - 90%
97R7 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
97R7 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.78
97R7 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
97R7 StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £215.74
97R7 StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £96.64
97R7 StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
97R7 StarTech.com DC Power Adapter - 5V, 3A In Stock £11.75
Price Range Ex VAT: £750 - £1000
