Product
StarTech.com 4U 19in Secure Horizontal Wall Mountable Server Rack - 2 Fans Included
Quicklinx: 7Y3WWS00 Mfr#: RK419WALVSGB
Product Type: Rack, Rack
£287.77 ex VAT
£345.32 inc VAT
Wall-mount your server or networking equipment horizontally or vertically. The RK419WALVSGB 4U 19-inch Secure Horizontal Wall-Mountable Server Rack is a lockable, solid steel storage rack that provides a robust solution for wall mounting telecom, network or server equipment, and includes two 120mm fans, for improved airflow. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
This 4U rack can be mounted to a wall in a server room, office, or above a doorway in rooms lacking the space for a full-size rack, to expand your workspace and keep your equipment protected from unauthorized access. The bracket mounting holes (used to mount to a wall or desk) are positioned at 16-inches apart, matching standard stud measurements for easy installation.
Constructed to EIA-RS310 standards, the wallmount server rack allows equipment to be mounted horizontally, and offers a hinged lockable front cover as well as a lockable body. Alternatively, non-rackmount equipment can be mounted vertically with the included bottom cover, using the rack as a wall case.
StarTech.com 4U 19in Secure Horizontal Wall Mountable Server Rack - rack - 4U
Rack
Placing / Mounting
Wall mountable
Fans Qty
Dual
Fan Diameter
120 mm
Air Flow
92-106 cfm
Noise Level
42 - 46 dBA
Rack Size
19"
Height (Rack Units)
4U
Product Material
Steel
64.3 cm x 72.5 cm x 22.4 cm
20.1 kg
Key lock, hinged
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
4U
64.3 cm
72.5 cm
22.4 cm
20.1 kg
Heatsink & Fan
Fans Qty
2
Fan Diameter
120 mm
Air Flow
92-106 cfm
Noise Level
42 - 46 dBA
Weight Limit
68 kg
Mounting Kit
Included
Key lock, hinged
EIA-310-D, UL, RoHS
Limited warranty - lifetime
7Y3W StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £15.74
7Y3W StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £14.19
7Y3W StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.10
Product Type: Rack
Product Type: Rack
Price Range Ex VAT: 150 - 300
