This 4U patch panel wall mount bracket is 4in deep and sturdily designed to provide a dependable solution for mounting a patch panel to a wall. The patch panel wall mount features a hinged design for easy access.
- StarTech.com 4U Hinged Wall Mount Patch Panel Bracket - 6 inch Deep - 19" Patch Panel Swing Rack for Shallow Network Equipment- 33lbs (WALLMOUNTH4) - wall mount bracket - 4U - 19"
- Product Type
- Wall mount bracket
- 49 cm x 10.5 cm x 18 cm
- Product Material
- Steel
- Height (Rack Units)
- 4U
- 2-year warranty
- Product Type
- Product Material
- Steel
- 4U
- 49 cm
- 10.5 cm
- 18 cm
- Rack Size
- 19"
- Limited warranty - 2 years
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £40.86 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £45.21 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £39.32 |
StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £44.29 |
StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £53.59 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £78.51 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £48.25 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.39 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £16.28 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £32.84 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.33 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £65.84 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £59.69 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £32.13 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £22.74 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £28.56 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £17.25 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £62.33 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £32.84 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £18.34 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £34.53 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £19.35 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.55 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £30.84 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £28.59 |
StarTech.com 2-Post Desktop Rack - 8U | In Stock | £37.91 |
StarTech.com 18U Server Rack Enclosure | In Stock | £452.59 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £149.52 |
StarTech.com 26U Server Rack Enclosure | In Stock | £495.72 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £175.15 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £194.68 |
StarTech.com 12U Server Rack Enclosure | In Stock | £402.13 |
StarTech.com 12U Server Rack Enclosure | In Stock | £277.35 |
StarTech.com 15U Server Rack Enclosure | In Stock | £344.58 |
StarTech.com 12U Server Rack Enclosure | In Stock | £377.14 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £32.74 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £17.54 |
