This SFP+ server network card delivers reliable, high-performance network connectivity, by adding four open SFP+ slots to your server or high-powered workstation. It provides an easy and cost-effective way to upgrade to a 10 Gigabit fiber network using SFP+ modules of your choice and gives you the flexibility to use either multimode or single-mode fiber.
Add redundant connections in zero-downtime environments
With multiple available ports, you can avoid network downtime by adding fault-tolerant connections using two or more modules to provide high-bandwidth network links to your mission-critical servers or workstations. -
Increase your network speed
This PCIe network card lets you take advantage of the increased speed and stability of a 10 Gigabit network, with data transfers of up to 10Gbps. -
Add scalable network connections to your server or workstation
The network interface card is compatible with most 10GbE SFP+ transceivers. This gives you flexible and scalable configuration options, for connecting your computer directly to a fiber network at greater distances. -
Enhance your network capabilities
The SFP+ server network card features the Intel XL710 chipset, delivering the power, performance and enhanced capabilities you need for reliable connections to your server or computer. The Intel chip offers many advanced features including Intel Virtualization Technology for Connectivity, PXE network boot support and up to 9K jumbo frame support.
- StarTech.com Quad Port 10G SFP+ Network Card, Intel XL710 Open SFP+ Converged Adapter, PCIe 10 Gigabit Ethernet Server NIC, 10GbE Fiber Optic LAN Card Dell PowerEdge HPE ProLiant, NIC Card - 10Gb SFP+ NIC Card (PEX10GSFP4I) - network adapter - PCIe x8 - 10 Gigabit SFP+ x 4
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x8
- Ports
- 15 cm x 13.9 cm x 12 cm
- 129 g
- Cabling Type
- Ethernet 10GBase-LR, Ethernet 10GBase-SR
- Data Link Protocol
- 10GbE
- Data Transfer Rate
- 20 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- Intel XL710
- IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae
- Black
- System Requirements
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions, Microsoft Windows Server 2019 (64-bit)
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x8
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 20 Gbps
- Capacity
- Full duplex capability, Jumbo Frames support
Processor / Memory
- Processor
- Intel XL710
- 4 x 10GBase-LR - SFP+
- FCC, RoHS, WEEE, RCM
- Black
- OS Required
- 15 cm
- 13.9 cm
- 12 cm
- 129 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 20 - 80%
StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £43.69 |
StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £51.33 |
StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £57.76 |
StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable | In Stock | £72.38 |
StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £38.70 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £307.47 |
