StarTech.com 4Port SFP+ PCIe Network Card
Quicklinx: CXPHWS00 Mfr#: PEX10GSFP4I
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Compatibility: PC, Unix
Type: Network adapter
12 in stock
£288.28 ex VAT
£345.93 inc VAT
This SFP+ server network card delivers reliable, high-performance network connectivity, by adding four open SFP+ slots to your server or high-powered workstation. It provides an easy and cost-effective way to upgrade to a 10 Gigabit fiber network using SFP+ modules of your choice and gives you the flexibility to use either multimode or single-mode fiber.
  • Add redundant connections in zero-downtime environments
    With multiple available ports, you can avoid network downtime by adding fault-tolerant connections using two or more modules to provide high-bandwidth network links to your mission-critical servers or workstations.
  • Increase your network speed
    This PCIe network card lets you take advantage of the increased speed and stability of a 10 Gigabit network, with data transfers of up to 10Gbps.
  • Add scalable network connections to your server or workstation
    The network interface card is compatible with most 10GbE SFP+ transceivers. This gives you flexible and scalable configuration options, for connecting your computer directly to a fiber network at greater distances.
  • Enhance your network capabilities
    The SFP+ server network card features the Intel XL710 chipset, delivering the power, performance and enhanced capabilities you need for reliable connections to your server or computer. The Intel chip offers many advanced features including Intel Virtualization Technology for Connectivity, PXE network boot support and up to 9K jumbo frame support.
StarTech.com Quad Port 10G SFP+ Network Card - Intel XL710 Open SFP+ Converged Adapter - PCIe 10 Gigabit Fiber Optic Server NIC - 10GbE - network adapter - PCIe x8 - 10 Gigabit SFP+ x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x8
Ports
10 Gigabit SFP+ x 4
15 cm x 13.9 cm x 12 cm
129 g
Cabling Type
Ethernet 10GBase-LR, Ethernet 10GBase-SR
10 GigE
Data Transfer Rate
20 Gbps
Jumbo frame size: 9000
Intel XL710
IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae
Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Microsoft Windows Server 2016 (64-bit), Linux 2.6.24 - 4.11.x (64-bit) LTS versions, Microsoft Windows Server 2019 (64-bit)
Network adapter
Plug-in card
PCI Express x8
Ports
10 Gigabit SFP+ x 4
Wired
Cabling Type
10 Gigabit Ethernet
Data Transfer Rate
20 Gbps
Full duplex capability, Jumbo Frames support
Processor / Memory
Intel XL710
4 x 10GBase-LR - SFP+
FCC, RoHS, WEEE, RCM
15 cm
13.9 cm
12 cm
129 g
5 °C
50 °C
20 - 80%
CXPH StarTech.com PCIe 10Gb Fiber Card SFP+ NIC In Stock £150.99
CXPH StarTech.com 10G Open SFP+ NIC - PCIe In Stock £167.63
CXPH StarTech.com 4Port SFP+ PCIe Network Card In Stock £288.28
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 150 - 300
