StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter  w/ Solid Aluminum Housing – 4K 30Hz
Quicklinx: 9PRDWS00 Mfr#: ST122HD4K
Split an HDMI audio/video source on two separate HDMI Displays simultaneously, with support for resolutions up to 4K. The ST122HD4K 2-port 4K HDMI splitter lets you share an HDMI display or projector with two HDMI-enabled audio / video source devices, such as computers, Blu-ray players and cable TV set-top boxes.
With support for Ultra HD (4K) the HDMI splitter ensures astonishing picture quality, four times the resolution of high-definition 1080p at 30 Hz. The 4K splitter is also backward compatible with previous HDMI revisions, supporting 1080p / 720p HDMI video resolution devices. Even if you don't require 4K video today, the ST124HD4K ensures you'll be ready to take advantage of tomorrow's display technology.
Constructed of solid aluminum, the HDMI splitter casing is heavy enough to prevent the unit from shifting or sliding around when you move the attached HDMI cables. Plus, the small footpring allows for seamless integration into any digital signage application.
StarTech.com HDMI Splitter 1 In 2 Out - 4k 30Hz - 2 Port - Aluminum - HDMI Multi Port - HDMI Audio Splitter (ST122HD4K) - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
HDMI
Ports
2 x HDMI
4K resolution support
AC 120/230 V
6.15 cm x 10 cm x 1.4 cm
157 g
P/N: SVA5H2NEUA
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
3840 x 2160
2 x HDMI output , 1 x HDMI input
External power adapter
AC 120/230 V
FCC, RoHS
6.15 cm
10 cm
1.4 cm
157 g
P/N: SVA5H2NEUA
9PRD StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
9PRD StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
9PRD StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £54.03
9PRD StarTech.com 4K HDMI 4-Port Video Splitter In Stock £62.23
9PRD StarTech.com DC Power Adapter - 5V, 2A In Stock £10.25
