StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter
Quicklinx: 9PRCWS00 Mfr#: ST122HD4KU
More than 50 In Stock
£54.03 ex VAT
£64.83 inc VAT
Split an HDMI audio/video source to two separate HDMI Displays, with support for HDMI 4K, and Power through a nearby USB port. The ST122HD4KU 2-port video splitter supports Ultra HD (4K) ensuring astonishing picture quality, four times the resolution of high-definition 1080p, while sharing a 4K HDMI video source between two HDMI displays.
The 4K splitter is backward compatible with previous HDMI revisions, supporting 1080p / 720p HDMI video resolution devices such as computers, Blu-ray players and cable TV set-top boxes. Even if you don't require 4K video today, the video splitter ensures you'll be ready to take advantage of tomorrow's display technology while still working with the devices you already have. Plus, this splitter supports 3D, enabling you to use the splitter with your stereoscopic 3D video source on active or passive 3D displays.
For a hassle-free setup you can power the HDMI splitter with the included USB cable, or power adapter depending on which is most convenient for you. Plus, the splitter features a built-in HDMI source cable, which lets you connect it directly to your HDMI source without the expense of additional cabling.
StarTech.com HDMI Cable Splitter - 2 Port - 4K 30Hz - Powered - HDMI Audio / Video Splitter - 1 in 2 Out - HDMI 1.4 - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
HDMI
Ports
2 x HDMI
5 cm x 62 cm x 1.8 cm
78 g
P/N: ST121SHD50, SVA5M3NEUA
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
3840 x 2160 @ 30 Hz
1 x HDMI input , 2 x HDMI output
External power adapter
1 x USB power cable
FCC, RoHS
5 cm
62 cm
1.8 cm
78 g
9PRC StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.28
9PRC StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable In Stock £4.95
9PRC StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £103.47
9PRC StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier In Stock £84.10
9PRC StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £11.42
9PRC StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
9PRC StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £96.64
9PRC StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
9PRC StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £54.03
9PRC StarTech.com 4K HDMI 4-Port Video Splitter In Stock £62.23
9PRC StarTech.com DC Power Adapter - 5V, 3A In Stock £12.05
9PRC StarTech.com 8-Port 4K 60Hz HDMI Splitter In Stock £134.78
9PRC StarTech.com HDMI Splitter - 4 Port - 4K 60Hz In Stock £54.71
9PRC StarTech.com 55-Bit Electric Precision Screwdriver Set In Stock £65.01
9PRC StarTech.com 2-Port HDMI Splitter, 4K 60Hz In Stock £56.78
