StarTech.com 4K DP Laptop Docking Station
Quicklinx: BTM2WS00 Mfr#: USB3VDOCK4DP
18 in stock
£99.36 ex VAT
£119.23 inc VAT
Set up a permanent or hoteling (hot desking) 4K workstation where fewer peripheral and device ports are needed, and in an area where desk space is limited. This 4K DisplayPort docking station for laptops offers a cost-effective way to create a simpler but highly functional Ultra HD workstation that can be used in permanent workspaces, or by multiple people in guest or hoteling (hot desk) environments.
If you don't need all the connections and features of a traditional laptop docking station, you can use this dock to add the most essential connections (such as an extra high-resolution display) to your laptop. With support for 4K cinema-quality resolution, it's great for graphic and web designers, video editors, and more.
Now you or your colleagues can be more productive and create an efficient and comfortable workspace, even in an area with minimal desk space.
This laptop dock features basic device connections that are integrated into a small foot-print housing. Now you can create a permanent or a hoteling (hot desking) workstation in a location with limited space. The dock offers an efficient solution for adding an extra display, a Gigabit network connection, and multiple USB devices without having to connect several individual adapters. And, with hotel desks or hot desks, laptop users aren't tied to one specific workstation, so they can come and go easily.
For users who require a boost in image quality, the dock offers a 4K DisplayPort connection that supports 4K x 2K (3840 x 2160p - 30Hz) Ultra HD resolution.
The DP dock offers simpler connectivity, so you can save money by avoiding a docking station that has connections you might never use. It's perfect for anyone who needs to expand their connectivity in virtually any environment or application.
It's a cost-effective docking station that still provides all the fundamental ports of a full-size workstation, such as an DisplayPort output, and when paired with your laptop display, you can easily set up dual monitors.
The 4K dock is perfect for professionals who work with highly detailed graphics, or large spreadsheets, such as engineers, animators, and financial analysts.
If you're running out of physical workspace, this USB 3.0 (also known as USB 3.1 Gen 1 - 5Gbps) docking station can help. Its compact design occupies minimal surface area, so you can integrate it into smaller areas than traditional docking stations or desktop computers would require.
By maximizing your available space, the compact dock can help eliminate the added cost and hassle of purchasing more offices, cubicles, or desks.
With fewer ports integrated into a small foot-print housing, the dock is a perfect fit for short-term work areas (hot desks). It's ideal for mass deployment in business, classroom, computer lab, and government settings. Plus, it integrates nicely into home-office or office-hoteling workspaces that have limited space.
You can avoid the aggravation of a dead battery and make sure your mobile device is always ready to go, using the dock's USB fast-charge and sync port. Plus, the always-on USB port supports device charging even when your laptop isn't connected to the dock.
When you're in a hurry, the easily accessible USB port charges your smartphone or tablet faster than traditional USB ports. This front-panel port ensures your mobile device is always within arm's reach, so you can simultaneously get your work done while enjoying convenient device charging at your workstation.
StarTech.com USB 3.0 Docking Station - Compatible with Windows / macOS - Supports a Single 4K Ultra HD DisplayPort Display - USB3VDOCK4DP - docking station - DP
Docking station
Docking Interface
USB
Video Interfaces
DP
7.9 cm x 13.9 cm x 2.6 cm
Black & silver
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
Docking station
7.9 cm
13.9 cm
2.6 cm
Enclosure Colour
Black & silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
1 x display / video - DisplayPort - 20 pin DisplayPort , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - headphones/microphone - mini-phone 3.5 mm 4-pole
1 x SuperSpeed USB cable - external
Security lock slot (cable lock sold separately), wake on LAN, LED indicator, UASP transfer protocol, 1 USB 3.0 fast charging port
FCC, RoHS, USB Battery Charging Specification Rev. 1.2
Power adapter
AC 120/230 V
Microsoft Windows 7 / 8 / 8.1 / 10, Google Chrome OS 55 or later, Apple MacOS X 10.8 - 10.13.3
Limited warranty - 3 years
5 °C
50 °C
StarTech.com 4K DP Laptop Docking Station Bundle deal on StarTech.com 4K DP Laptop Docking Station
£198.53
BTM2 StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £120.39
BTM2 StarTech.com Triple-Video Laptop Dock In Stock £149.59
BTM2 StarTech.com Docking Station for 2 Laptops In Stock £156.24
BTM2 StarTech.com DVI Laptop Docking Station In Stock £66.45
BTM2 StarTech.com 4K DP Laptop Docking Station In Stock £99.36
Price Range Ex VAT: 50 - 100
