This SATA Power Y-Splitter adapter cable features three Serial ATA power outputs, allowing you to split a single SATA power supply connection into three. This high quality SATA power splitter is built with only the highest quality components to ensure peak performance.
- StarTech.com 4in SATA Power Y Splitter Adapter Cable - power splitter - SATA power to SATA power - 12 cm
- Power splitter
- Length
- 12 cm
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 3 x 15 pin Serial ATA power - female
- Designed For
- P/N: S25SLOTR, S32M2NGFFPEX, SAT32MSATPEX
- Power splitter
- Length
- 12 cm
- Connector
- Designed For
