StarTech.com 4in SATA Power Y Splitter Adapter Cable
Quicklinx: 7B79WS00 Mfr#: PYO3SATA
This SATA Power Y-Splitter adapter cable features three Serial ATA power outputs, allowing you to split a single SATA power supply connection into three. This high quality SATA power splitter is built with only the highest quality components to ensure peak performance.
StarTech.com 4in SATA Power Y Splitter Adapter Cable - power splitter - SATA power to SATA power - 12 cm
Power splitter
Length
12 cm
Connector
15 pin Serial ATA power - male
Connector (Second End)
3 x 15 pin Serial ATA power - female
P/N: S25SLOTR, S32M2NGFFPEX, SAT32MSATPEX
Power splitter
Length
12 cm
Connector
