Build or upgrade a computer system with an energy efficient and reliable 450 Watt Gold ATX power supply. The ATX2PW450GO 450 Watt 80 Plus Gold Power Supply offers an energy efficient replacement or upgrade for powering your desktop PC. Operating at an 87% to 90% efficiency between 20% and 100% load, 80 Plus Gold power supplies deliver a significant improvement over standard-efficiency power supplies that helps reduce energy consumption and cost of operation.
This versatile power supply is equipped to support AMD or Intel CPU-based servers and workstations with a combined 20/24-pin motherboard connection, and an 8-pin EPS connector.
- StarTech.com 450 Watt ATX12V 2.3 80 Plus Gold Power Supply w/ Active PFC - power supply - 450 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, ±5, ±12 V
- Power Capacity
- 450 Watt
- Output Current
- +12V1 - 37 A , +12V2 - 37 A , +12V3 - 37 A , +12V4 - 37 A , +3.3V - 20 A , +5V - 20 A , -12V - 0.5 A , +5VSB - 2.5 A , -5V - 37 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 8 pin PCI Express power , 4 x 15 pin Serial ATA power , 3 x 4 PIN internal power
- Cooling System
- 120 mm fan
- Black
- 15 cm x 14 cm x 8.6 cm
- 2-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 110 - 240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, ±5, ±12 V
- Power Capacity
- 450 Watt
- Output Current
- 80 PLUS Gold
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, quad 12V rails, short-circuit protection, non-modular
- UL, FCC, RoHS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
- 15 cm
- 14 cm
- 8.6 cm
