StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks
Quicklinx: 97RHWS00 Mfr#: 4POSTRACK42
Depth (mm): 59.18cm
Type: Floor standing
U Height: 42U
Width (mm): 60cm
11 in stock
£204.95 ex VAT
£245.94 inc VAT
Store your servers, network and telecommunications equipment in this adjustable 42U open-frame rack. The 4POSTRACK42 42U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 42U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1320lbs (600kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete rack solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securing the rack to the floor if needed, providing you with many options to customize the rack to fit your environment.
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack - Flat Pack rack - 42U
Rack
Package Content
50 x M6 screw, 16 x M6 screw, 50 x M6 cage nut, 4 vertical rack rails, 24 mounting screws, 2 base brackets, 2 top brackets, 48 x M8 bolts, 8 x corner sections, 48 x M8 washers, M8 (13mm) wrench, 50 PVC cup washers, 24 cable management hooks, 4 x casters, 4 x levelling feet, 32 x M6 flat washers, 16 x M6 flange nuts
Height (Rack Units)
42U
Product Material
Steel
60 cm x 59.18 cm x 197.1 cm
38.5 kg
Rack
Product Material
Steel
Package Content
Height (Rack Units)
42U
60 cm
59.18 cm
197.1 cm
38.5 kg
Weight Limit
600 kg
RoHS, DIN 41494, IEC 60297-3-100
97RH StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £57.39
97RH StarTech.com 1U Velcro Horizontal Server Rack Cable Management Panel - 4 Loop Cable Organizer In Stock £12.24
97RH StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £204.95
97RH StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £135.28
Depth (mm): 59.18cm
U Height: 42U
Width (mm): 60cm
Price Range Ex VAT: 150 - 300
