Add additional chassis cooling with a 40mm ball bearing fan. This 40mmx10mm PC computer cooling fan is a perfect addition or replacement PC fan for maintaining suitable operating temperatures within your computer case. The PC fan can be powered through a simple LP4 connection to the PC power supply and offers a dual ball bearing design to ensure quiet, dependable operation.
- StarTech.com 40x10mm Replacement Dual Ball Bearing Computer Case Fan w/ LP4 - system fan kit
- Product Type
- System fan kit
- Fan Diameter
- 40 mm
- Noise Level
- 23 dB
- 25 g
- 2 years warranty
- Product Type
- System fan kit
- 25 g
Heatsink & Fan
- Fan Diameter
- 40 mm
- Noise Level
- 23 dB
- Limited warranty - 2 years
- -10 °C
- 80 °C
