Product
StarTech.com 40x10mm Replacement Dual Ball Bearing Computer Case Fan with LP4
Quicklinx: 76SFWS00 Mfr#: FAN4X1LP4
Type: Case Fan
47 in stock
£5.07 ex VAT
£6.08 inc VAT
Add additional chassis cooling with a 40mm ball bearing fan. This 40mmx10mm PC computer cooling fan is a perfect addition or replacement PC fan for maintaining suitable operating temperatures within your computer case. The PC fan can be powered through a simple LP4 connection to the PC power supply and offers a dual ball bearing design to ensure quiet, dependable operation.
StarTech.com 40x10mm Replacement Dual Ball Bearing Computer Case Fan w/ LP4 - system fan kit
System fan kit
Fan Diameter
40 mm
Noise Level
23 dB
25 g
2 years warranty
System fan kit
25 g
Heatsink & Fan
Fan Diameter
40 mm
Noise Level
23 dB
-10 °C
80 °C
Type: Case Fan
Price Range Ex VAT: 0 - 50
