Product
StarTech.com 40GBase-SR4 QSFP+ MPO MM 150m
Quicklinx: D1V1WS00 Mfr#: QSFP40SR4ST
£213.45 ex VAT
£256.14 inc VAT
Add reliable and cost-effective 40 Gigabit Ethernet connections over multimode fiber, with this QSFP+ module. This 40GBase-SR4 QSFP+ module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The multimode QSFP+ transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 40Gbps and support for Digital Diagnostics Monitoring (DDM / DOM), this QSFP+ module can be installed into fiber networking equipment with an MSA compliant port, using an MPO connector. It delivers dependable 40 Gigabit connectivity over multimode fiber for 40GBase-SR4 compliant networks, with a maximum distance of up to 150 m (492 ft.) and 850 nm optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
StarTech.com 40GBASE-SR4 Fiber QSFP+ Module - Lifetime Warranty - QSFP+ transceiver module - 40 Gigabit LAN
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40 Gigabit LAN
Max Transfer Distance
150 m
1.84 cm x 7.2 cm x 0.85 cm
40 g
Plug-in module
Silver
Wired
Cabling Type
40GBASE-SR4
40 Gigabit LAN
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
150 m
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3ba
1 x Ethernet 40GBASE-SR4 - MPO multi-mode
MTBF
1,489,426 hours
UL, FCC, RoHS, MSA
1.84 cm
7.2 cm
0.85 cm
40 g
Limited warranty - lifetime
70 °C
5 - 95%
Price Range Ex VAT: 150 - 300
