StarTech.com 40-Pin IDE PATA to SATA Adapter Converter for HDD/SSD/ODD
Quicklinx: 9N9TWS00 Mfr#: IDE2SAT2
Type: Adapter
More than 50 in stock
£14.47 ex VAT
£17.36 inc VAT
Connect your SATA Hard Drive or Blu-ray/DVD/CD-ROM Drive to an IDE motherboard. The IDE2SAT240-pin IDE to SATA adapter enables you to connect a SATA I/II/III drive to an available IDE/ATA 33/66/100/133 motherboard port - a cost-effective solution that allows you to add newer SATA drives, and keep your existing motherboard.
The IDE/SATA adapter offers a cost-effective solution for bridging the gap between a newer 2.5"/3.5"/5.25" SATA drive and older IDE motherboard port. The IDE2SAT2 also features ODD (Optical Disk Drive) support, allowing you to a add Blu-ray, DVD, or CD-ROM drives to an older IDE motherboard.
StarTech.com 40-Pin IDE PATA to SATA Adapter Converter - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Storage controller
Bus Type
Ultra ATA/133
SATA 1.5Gb/s
Data Transfer Rate
133 MBps
Supported Devices
Hard drive, CD drive, DVD drive
Channel Qty
1
Max Storage Devices Qty
1
2 cm x 7.55 cm x 2.3 cm
15 g
Storage controller
Host Bus
Ultra ATA/133
Storage Controller
SATA 1.5Gb/s
Data Transfer Rate
133 MBps
Supported Devices
Channel Qty
1
1
1 x SATA 1.5Gb/s - SATA combo
1 - 40 PIN IDC
1 x power cable
FCC, RoHS
2 cm
7.55 cm
2.3 cm
15 g
9N9T StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £2.82
9N9T StarTech.com 18in Dual Drive Ultra ATA IDE Hard Drive Cable In Stock £3.58
9N9T StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £12.23
Type: Adapter
Price Range Ex VAT: 0 - 50
