Allows connection of a SATA device to an IDE motherboard or card.
This IDE to SATA adapter converts a 40-pin IDE connector to a SATA connector, allowing you to connect a 2.5in or 3.5in SATA (SATA, SATA II/SATA 300) drive to the motherboard in place of an IDE drive.
The IDE to SATA Adapter is suitable for installation in any computer case, as it is requires minimal space and does not impact airflow.
- StarTech.com 40 Pin Female IDE to SATA Adapter Converter - Connect a SATA device to an IDE controller - IDE to SATA Converter (IDE2SAT25) - storage controller - ATA - SATA
- Storage controller - internal
- Bus Type
- SATA
- Interface
- ATA
- Data Transfer Rate
- 133 MBps
- Supported Devices
- Hard drive
- Channel Qty
- 1
- System Requirements
- Microsoft Windows Vista / 2000 / XP
- 3.2 cm x 8 cm x 0.9 cm
- 12 g
- Limited lifetime warranty
- Designed For
- P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F
- Host Bus
- SATA
Storage Controller
- Interface
- ATA
- 133 MBps
- Supported Devices
- Hard drive
- Channel Qty
- 1
- 1 x ATA - 40 PIN IDC
- Connections
- 1 storage - Serial ATA-150 - 7 pin Serial ATA
- FCC, RoHS
- OS Required
- Limited warranty - lifetime
- 3.2 cm
- 8 cm
- 0.9 cm
- 12 g
- Designed For
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
StarTech.com Bi-Directional SATA IDE Adapter Converter | In Stock | £11.78 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £20.67 |
StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDD | In Stock | £23.69 |
