StarTech.com 40 Pin Female IDE to SATA Adapter Converter
Quicklinx: 5JR3WS00 Mfr#: IDE2SAT25
£10.91 ex VAT
£13.09 inc VAT
Allows connection of a SATA device to an IDE motherboard or card.
This IDE to SATA adapter converts a 40-pin IDE connector to a SATA connector, allowing you to connect a 2.5in or 3.5in SATA (SATA, SATA II/SATA 300) drive to the motherboard in place of an IDE drive.
The IDE to SATA Adapter is suitable for installation in any computer case, as it is requires minimal space and does not impact airflow.
StarTech.com 40 Pin Female IDE to SATA Adapter Converter - Connect a SATA device to an IDE controller - IDE to SATA Converter (IDE2SAT25) - storage controller - ATA - SATA
Storage controller - internal
Bus Type
SATA
ATA
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
Microsoft Windows Vista / 2000 / XP
3.2 cm x 8 cm x 0.9 cm
12 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F
Host Bus
SATA
Storage Controller
ATA
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Channel Qty
1
1 x ATA - 40 PIN IDC
1 storage - Serial ATA-150 - 7 pin Serial ATA
FCC, RoHS
Limited warranty - lifetime
3.2 cm
8 cm
0.9 cm
12 g
5JR3 StarTech.com 18in SATA Serial ATA Cable In Stock £3.36
5JR3 StarTech.com 18in Dual Drive Ultra ATA IDE Hard Drive Cable In Stock £3.59
5JR3 StarTech.com 36in SATA Serial ATA Cable In Stock £3.17
5JR3 StarTech.com 40 Pin Female IDE to SATA Adapter Converter In Stock £10.91
5JR3 StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDD In Stock £22.35
Resources
The following resources are available for the StarTech.com 40 Pin Female IDE to SATA Adapter Converter
Price Range Ex VAT: 0 - 50
