StarTech.com 40 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P01WS00 Mfr#: MXT101MMHQ40
This 40-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 40 ft. (12.2 m) VGA to VGA Cable - HD15 Male to HD15 Male - Triple-Coaxial - High Quality - VGA Monitor Cable (MXT101MMHQ40) - VGA cable - 12.2 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
12.2 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
P/N: CDP2VGA, CDP2VGAFC, DVI2VGAE, DVIVGAMF, DVIVGAMFBK, HD2VGAE2, HD2VGAMICRO
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
12.2 m
Connector
7P01 StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.07
7P01 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £7.06
