StarTech.com 40 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P01WS00 Mfr#: MXT101MMHQ40
Length: 12.2m
15 in stock
£21.45 ex VAT
£25.74 inc VAT
This 40-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 40 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 12.2 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
12.2 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
12.2 m
Connector
7P01 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
7P01 StarTech.com 40 ft Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £21.45
Length: 12.2m
Price Range Ex VAT: 0 - 50
