StarTech.com 4-to-1 HDMI Video Switch with Remote Control
Quicklinx: 6BCJWS00 Mfr#: VS410HDMIE
Select:
  • HDMI
This 4 port HDMI Switch lets you connect up to four HDMI output devices to a single HDMI input - eliminating the need to manually exchange cables to switch between high definition audio video sources.
The HDMI switch fully supports HDMI device connections, as well as display resolutions up to 1080p(HDTV) / 1920x1200(computer), ensuring a high quality audio and video experience. Suitable for long distance connections, the switch offers a signal enhancement feature that can be used with longer cable connections, boosting the HDMI signal for optimized quality.
The switch provides an economical solution for connecting multiple HDMI out devices (Blu-Ray players, DVD Players, etc.) to a single port on a high definition LCD/Plasma TV.
StarTech.com 4-to-1 HDMI Video Switch with Remote Control - Video/audio switch - 4 x HDMI - desktop - VS410HDMIE - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
Ports
4 x HDMI
HDCP compliant
HDCP 1.1, DVI 1.0
24 cm x 10.4 cm x 4.4 cm
1.25 kg
1-year warranty
P/N: SVA5M3NEUA
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
Max Resolution
1920 x 1200 / 1080p
HDCP compliant, HDTV support
HDCP 1.1, DVI 1.0
4 x HDMI , 1 x HDMI
External power adapter
Wireless remote control
FCC, RoHS
24 cm
10.4 cm
4.4 cm
1.25 kg
Limited warranty - 1 year
P/N: SVA5M3NEUA
