StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention
Quicklinx: 660JWS00 Mfr#: ICUSB2324X
£63.89 ex VAT
£76.66 inc VAT
The ICUSB2324X 4 Port Professional Grade USB Serial Adapter converts a single USB port to four RS232 serial ports allowing you to connect to, monitor and control your serial devices. Rugged metal construction and sturdy wall-mount brackets provide a robust solution for both harsh industrial environments and simple desktop installations. Powered by USB, the device does not require a power outlet for most standard applications. For installations requiring power through the RS232 ports, optional DC connector and terminal block connections are included. Once connected, the adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the ports provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative Serial adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading serial peripherals for USB compatibility.
StarTech.com USB to Serial Adapter Hub - 4 Port - Wall Mount - COM Port Retention - Texas Instruments - USB to RS232 Adapter (ICUSB2324X) - serial adapter
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232 x 4
16.5 cm x 11.8 cm x 2.5 cm
0.6 kg
RS-232
Data Transfer Rate
230 Kbps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Serial adapter
External
USB
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
230 Kbps
4 x RS-232 - 9 pin D-Sub (DB-9) - male
FCC, RoHS
Software Included
Drivers & Utilities
16.5 cm
11.8 cm
2.5 cm
0.6 kg
660J StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.87
660J StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.93
660J StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £14.45
660J StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £21.12
660J StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £63.89
660J StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £35.74
660J StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub In Stock £137.49
660J StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.10
660J StarTech.com 4 Port USB to Serial Hub In Stock £54.25
Price Range Ex VAT: 50 - 100
