The ICUSB2324X 4 Port Professional Grade USB Serial Adapter converts a single USB port to four RS232 serial ports allowing you to connect to, monitor and control your serial devices. Rugged metal construction and sturdy wall-mount brackets provide a robust solution for both harsh industrial environments and simple desktop installations. Powered by USB, the device does not require a power outlet for most standard applications. For installations requiring power through the RS232 ports, optional DC connector and terminal block connections are included. Once connected, the adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the ports provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative Serial adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading serial peripherals for USB compatibility.
- StarTech.com USB to Serial Adapter Hub - 4 Port - Wall Mount - COM Port Retention - Texas Instruments - USB to RS232 Adapter (ICUSB2324X) - serial adapter - USB - RS-232 x 4
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232 x 4
- 16.5 cm x 11.8 cm x 2.5 cm
- 0.6 kg
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 230 Kbps
- Black
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232 x 4
- Connectivity Technology
- Wired
- RS-232
- 230 Kbps
- 4 x RS-232 - 9 pin D-Sub (DB-9) - male
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 16.5 cm
- 11.8 cm
- 2.5 cm
- 0.6 kg
- Limited warranty - 2 years
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M | In Stock | £3.84 |
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £14.62 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £21.31 |
StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention | In Stock | £62.80 |
StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention | In Stock | £35.13 |
StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub | In Stock | £134.94 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F | In Stock | £4.07 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £53.33 |
