Your basket is empty
StarTech.com 4 Port VGA Video Splitter - 250 MHz
Quicklinx: 4H1GWS00 Mfr#: ST124LGB
The ST124LGB 4 port VGA video splitter allows a single VGA source to display VGA video onto four monitors simultaneously. Perfect for classrooms, tradeshows, or in-store displays where high quality video on several monitors is needed. The simple plug and play operation makes setup quick and easy so you can be up and running in minutes.
The ST124LGB supports up to 250 MHz of video bandwidth, providing brilliant resolutions up to 1920x1440. A built-in booster circuit lets you situate your displays up to 210 ft away from your source.
StarTech.com 4 Port VGA Video Splitter - 250 MHz - video splitter - 4 ports
Video splitter - 4 ports
Subtype
VGA
Ports
4 x VGA
20.5 cm x 6.5 cm x 2.6 cm
450 g
United Kingdom
2 years warranty
Enclosure Type
Desktop
Subtype
VGA
Ports
4 x VGA
Max Resolution
1920 x 1440
Max Video Bandwidth
250 MHz
4 x VGA output HD-15 , 1 x VGA input HD-15
External power adapter
FCC
United Kingdom
20.5 cm
6.5 cm
2.6 cm
450 g
4H1G StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.75
