StarTech.com 4 Port VGA Video Extender over Cat 5 (UTPE Series)
Quicklinx: 82HVWS00 Mfr#: ST124UTPE
Extend and distribute your VGA video signal to up to four remote displays using Cat 5 cabling. The ST124UTPE 4 Port VGA Video Extender over Cat 5 (UTPE Series) allows up to 5 (1 local and 4 remote) monitors to be connected to a single VGA source.
The video signal is carried to the remote monitors over standard 4 pair Category 5 and Category 6 UTP cable using RJ45 connectors and supports distances of up to 300m / 950ft.
At each remote monitor an STUTPRXL receiver is required. The receiver unit converts the signal from the UTP cable back into VGA video for the monitor.
StarTech.com 4 Port VGA Video Extender over Cat 5 (UTPE Series) - video splitter - 4 ports
Video splitter - 4 ports
13 cm x 8.4 cm x 3 cm
0.2 kg
1-year warranty
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Max Resolution
1024 x 768 @ 60 Hz
Status Indicators
1 x VGA output HD-15 , Display / video: 4 x RJ-45 , 1 x VGA input HD-15
External power adapter
FCC
13 cm
8.4 cm
3 cm
0.2 kg
1-year warranty
