StarTech.com 4 Port VGA Video Audio Switch with RS232 control
Quicklinx: 679VWS00 Mfr#: VS410RVGAA
Type: Switch
Select:
£131.98 ex VAT
£158.37 inc VAT
This 4 Port VGA Video and Audio Switch lets you switch between four separate VGA signals, as well as the corresponding audio, for output to a single display or projector.
An ideal solution for situations where VGA and audio input ports are scarce, the VGA switch eliminates the hassle of having to swap out connections to your display and audio receiver, while letting you select the video source at the push of a button.
The VGA switch also features convenient remote switching capability, through either RS232 serial remote control or the included IR remote control - allowing you to switch between VGA input signals from a distance and in turn providing a convenient addition to presentation displays, trade shows, security environments and more.
StarTech.com 4 Port VGA Video Audio Switch with RS232 control - video/audio splitter - 4 ports
Video/audio splitter - 4 ports
29.2 cm x 7.3 cm x 4.4 cm
P/N: SVA5M3NEUA
Enclosure Type
Desktop
Max Resolution
1920 x 1200 / 1080p
Max Video Bandwidth
650 MHz
Status Indicators
Port status, power
4 x VGA HD-15 , 4 x audio output mini-jack , 1 x VGA HD-15 , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x audio input mini-jack
External power adapter
Wireless remote control
1 x VGA / USB cable - 91 cm
FCC, RoHS
29.2 cm
7.3 cm
4.4 cm
P/N: SVA5M3NEUA
679V StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.82
679V StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £3.66
Type: Switch
Price Range Ex VAT: 100 - 150
