StarTech.com 4 Port USB VGA KVM Switch with DDM Fast Switching Technology and Cables
Quicklinx: 95R0WS00 Mfr#: SV431USBDDM
Type: KVM / USB switch
Connectivity: KVM
Ports: 4
Hurry, only 3 left in stock!
£205.48 ex VAT
£246.57 inc VAT
Control 4 VGA, USB-equipped PCs with a single peripheral set, with USB Dynamic Device Mapping to avoid switching lag-time.
The SV431USBDDM 4-Port USB VGA KVM Switch lets you control 4 VGA, USB-equipped PCs using a single peripheral set at high-definition VGA resolutions up to 1920x1440.
The included KVM cables provide a ready-out-of-the-box solution, while USB Dynamic Device Mapping (DDM) and Display Data Channel (DDC) features work to significantly reduce switching lag-time and improve overall compatibility with your connected display and input devices, saving you time and money.
For the next level in KVM performance, this VGA KVM switch integrates multi-core dedicated processing per channel and innovative, USB DDM technology that enables you to quickly switch between connected computers with next-to-zero delay. DDM maintains a constant communication channel between your USB peripherals and connected systems, avoiding the time necessary for your systems to re-recognize the devices when switching.
In addition to faster switching, the KVM offers All-time Display Data Channel (Full DDC) technology to maintain proper display detection among connected systems, a simple one-touch button for hot-key selection and an integrated 2-port USB hub allowing you to share additional peripherals
StarTech.com 4 Port USB VGA KVM Switch with DDM Fast Switching and Cables - KVM / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / USB
KVM Users Qty
1 local user
AC 120/230 V
13.1 cm x 27.5 cm x 4.4 cm
1.1 kg
North America, United Kingdom, Europe
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / USB
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
4 x VGA HD-15 , 2 x keyboard (USB) / mouse (USB) Type A , 1 x VGA HD-15 , 4 x USB Type B , 1 x USB Type A , 1 x RJ-45
External power adapter
AC 120/230 V
FCC, RoHS
13.1 cm
27.5 cm
4.4 cm
1.1 kg
60 °C
0 - 80% (non-condensing)
Min Storage Temperature
-30 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95R0 StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
95R0 StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.90
95R0 StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £107.19
95R0 StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £159.68
95R0 StarTech.com 2 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables In Stock £150.87
95R0 StarTech.com 4 Port USB VGA KVM Switch with DDM Fast Switching Technology and Cables In Stock £205.48
Connectivity: KVM
Ports: 4
Price Range Ex VAT: 150 - 300
