StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable
Quicklinx: 89CQWS00 Mfr#: ICUSB2324I
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB 2.0
More than 50 in stock
£64.55 ex VAT
£77.46 inc VAT
Add 4 DIN Rail-mountable RS232 Serial ports to any system through USB. The ICUSB2324I 4-Port Industrial USB to Serial Hub with DIN Rail Clips converts a single USB port into four RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this USB to Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the ports provided by the adapter.
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub - Wall Mountable - serial adapter
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 4
6.65 cm x 15 cm x 2.6 cm
450 g
RS-232
Data Transfer Rate
921.6 Kbps
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
Serial adapter
External
USB 2.0
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
921.6 Kbps
USB powered
4 x RS-232 - 9 pin D-Sub (DB-9) - male
1 x USB cable (external) - 1.8 m
FCC, RoHS
Software Included
Drivers & Utilities
6.65 cm
15 cm
2.6 cm
450 g
55 °C
5 - 95%
89CQ StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
89CQ StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
89CQ StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F In Stock £5.93
89CQ StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Compatibility: Mac
Compatibility: PC
Interface: USB 2.0
Price Range Ex VAT: 50 - 100
