StarTech.com 4 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables
Quicklinx: 9TVBWS00 Mfr#: SV431DVIUDDM
Type: KVM / USB switch
Connectivity: KVM
Ports: 4
£210.27 ex VAT
£252.32 inc VAT
Control 4 DVI, USB-equipped PCs with a single peripheral set, with USB Dynamic Device Mapping to avoid switching lag-time. The SV431DVIUDDM 4-Port USB DVI KVM Switch lets you control 4 DVI, USB-equipped PCs using a single peripheral set at high-definition DVI resolutions up to 1920x1200.
The included KVM cables provide a ready-out-of-the-box solution, while USB Dynamic Device Mapping (DDM) and Display Data Channel (DDC) features work to significantly reduce switching lag-time and improve overall compatibility with your connected display and input devices, saving you time and money.
For the next level in KVM performance, this DVI KVM switch integrates dual-core dedicated processing per channel and innovative, USB DDM technology that enables you to quickly switch between connected computers with next-to-zero delay. DDM maintains a constant communication channel between your USB peripherals and connected systems, avoiding the time necessary for your systems to re-recognize the devices when switching.
In addition to faster switching, the KVM offers All-time Display Data Channel (Full DDC) technology to maintain proper display detection among connected systems, a simple one-touch button for hot-key selection and an integrated 2-port USB hub allowing you to share additional peripherals.
StarTech.com 4 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables - Four Port DVI USB KVM Switch - DDM KVM Switch (SV431DVIUDDM) - KVM / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / USB
KVM Users Qty
1 local user
AC 120/230 V
13.1 cm x 27.5 cm x 4.4 cm
1.2 kg
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / USB
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
4 x DVI-I (dual link) , 2 x keyboard (USB) / mouse (USB) Type A , 1 x DVI-I , 4 x USB Type B , 1 x USB Type A , 1 x RJ-45
External power adapter
AC 120/230 V
FCC, RoHS
13.1 cm
27.5 cm
4.4 cm
1.2 kg
60 °C
0 - 80% (non-condensing)
Min Storage Temperature
-30 °C
Max Storage Temperature
70 °C
Humidity Range Storage
9TVB StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £13.05
9TVB StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.71
9TVB StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £192.36
9TVB StarTech.com 4 Port USB VGA KVM Switch with DDM Fast Switching Technology and Cables In Stock £207.64
9TVB StarTech.com 2 Port USB VGA KVM Switch with DDM Fast Switching Technology and Cables In Stock £141.81
9TVB StarTech.com 4 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables In Stock £209.86
9TVB StarTech.com DC Power Adapter - 5V, 3A In Stock £10.80
Connectivity: KVM
Ports: 4
Price Range Ex VAT: 150 - 300
