StarTech.com 4 Port USB C Hub with PD 2.0
Quicklinx: CTJDWS00 Mfr#: HB30C4AFPD
Type: USB Hub
Interface: SuperSpeed USB 3.0, USB 3.1 Type C
Ports: 4
18 in stock
£32.32 ex VAT
£38.78 inc VAT
Turn a USB Type-C port on your laptop into four USB Type-A ports (5Gbps), plus power and charge your laptop. This compact USB 3.0 hub lets you add four USB-A ports to your laptop, with support for USB power delivery. This means that you can power and charge your laptop through its USB-C port while simultaneously powering the hub.
With its integrated USB Type-C cable and small-footprint design, this versatile hub offers a perfectly portable solution for connecting devices that require traditional USB Type-A ports to your USB-C or Thunderbolt 3 equipped computer.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
This USB-C 3.0 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
This USB hub is multi-platform compatible, which means it will work with a wide range of USB-C laptops that use a USB-C power adapter. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
StarTech.com 4 Port USB C Hub with PD 2.0 - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered, USB Attached SCSI Protocol (UASP)
USB 1.1, USB 2.0, USB 3.0, USB 3.1
4 cm x 9.3 cm x 1.1 cm
40.5 g
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X VIA VL812
4 x USB 3.0 output Type A , 1 x USB 3.0 input Type C
1 x SuperSpeed USB-C cable - 15 cm
Plug and Play, FCC, RoHS, WEEE, USB Power Delivery 2.0
4 cm
9.3 cm
1.1 cm
40.5 g
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Type: USB Hub
Interface: USB 3.1 Type C
Ports: 4
Price Range Ex VAT: 0 - 50
