StarTech.com 4-Port USB-C Hub - USB 3.1
Quicklinx: DPJDWS00 Mfr#: HB31C4AB
Type: USB Hub
Interface: SuperSpeed USB 3.0
Ports: 4
12 in stock
£32.84 ex VAT
£39.40 inc VAT
USB Type C Hub , Bus-powered. Expand the connectivity of your USB-C laptop with this new-generation USB-C 10G hub. It plugs into your laptop's USB Type-C or Thunderbolt 3 port, adding four USB 3.1 Gen 2 Type-A ports, so you can quickly connect more USB devices. It's bus-powered, so there's no external power adapter required.
This four-port USB Type-C hub enhances your productivity, giving you the connections you need while you work. Connect the latest USB devices, like flash drives, capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps, to save time when transferring large files.
The USB-C hub also lets you extend the life of your existing USB devices - it's backward compatible with previous versions of USB devices.
The compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop. It's bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. It also has a built-in cable (9.8 in./25 cm) for convenient travel.
The USB 3.1 hub works with a wide range of operating systems, including macOS, Windows and Linux. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly.
StarTech.com USB-C Hub - 4x USB-A Ports - 10Gbps - Bus Powered - USB C to USB 3.1 Gen 2 Hub - USB Type C Hub - Thunderbolt 3 USB Hub (HB31C4AB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
1.58 cm x 4.3 cm x 1.7 cm
62 g
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X VIA Labs VL820 VL820
Status Indicators
4 x USB 3.0 Type A
1 x USB-C cable - 25 cm
FCC, RoHS
1.58 cm
4.3 cm
1.7 cm
62 g
Shipping Weight
124 g
45 °C
20 - 80% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
DPJD StarTech.com 1m (3ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.11
DPJD StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £5.35
DPJD StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £7.21
DPJD StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £26.24
DPJD StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £43.47
DPJD StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £30.50
DPJD StarTech.com 4 Port USB C Hub - C to C & A In Stock £23.70
DPJD StarTech.com 4 Port USB-C Hub - C to C & A In Stock £42.37
DPJD StarTech.com 7 Port USB C Hub - C to C & A In Stock £56.78
Type: USB Hub
Ports: 4
Price Range Ex VAT: 0 - 50
