Add three USB-A ports and one USB-C port, via two host controllers, through a standard PCI Express slot. This USB 3.1 PCIe card lets you add three USB Type-A ports and one USB Type-C port to your computer, through a PCI Express slot. It makes it easy to upgrade your PC to the faster speed of USB 3.1 (10Gbps) so that you can access newer peripherals at twice the speed of traditional USB 3.0 (5Gbps) cards.
When multiple devices are connected, traditional single-bus USB cards share the maximum bandwidth between all ports. By employing two host controller chipsets, shared across two ports rather than four, this 4-port PCIe to USB 3.1 card dedicates up to 10Gbps for each set of two USB ports. It reduces performance bottlenecks and doubles your total available bandwidth to 20Gbps.
With higher data throughput support, the card is ideal for external hard drives, hard drive enclosures, and large external storage devices. It lets you access multiple devices simultaneously for read and write access.
The 4-port USB 3.1controller card adds dual independent channels to your computer and shares 10Gbps of bandwidth between two USB ports.
Each set of two ports shares a combined bandwidth of 10Gbps. If a single device is accessing the channel, the card will provide data transfer rates of up to 10Gbps to the device. If two devices are accessing the channel simultaneously, the 10Gbps of bandwidth will be shared between both devices.
Faster USB performance
When multiple devices are connected, traditional single-bus USB cards share the maximum bandwidth between all ports. By employing two host controller chipsets, shared across two ports rather than four, this 4-port PCIe to USB 3.2 card dedicates up to 10Gbps for each set of two USB ports. It reduces performance bottlenecks and doubles your total available bandwidth to 20Gbps. With higher data throughput support, the card is ideal for external hard drives, hard drive enclosures, and large external storage devices. It lets you access multiple devices simultaneously for read and write access. -
Shared bandwidth
The 4-port USB 3.2 controller card adds dual independent channels to your computer and shares 10Gbps of bandwidth between two USB ports. Each set of two ports shares a combined bandwidth of 10Gbps. If a single device is accessing the channel, the card will provide data transfer rates of up to 10Gbps to the device. If two devices are accessing the channel simultaneously, the 10Gbps of bandwidth will be shared between both devices. The PEXUS313AC2V is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 4 Port USB 3.1 PCIe Card - 1x USB C & 2x A - 2 10Gbps Channels (PEXUS313AC2V) - USB adapter - PCIe 3.0 x4 - USB 3.1 Gen 2 x 3 + USB-C 3.1 Gen 2 x 1
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 3.0 x4
- PCI Specification Revision
- PCIe 3.0
- Ports
- Data Link Protocol
- USB, USB 2.0, USB 3.0, USB 3.1
- Data Transfer Rate
- 10 Gbps
- USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits), Apple macOS 10.13
- 2-year warranty
- Designed For
- P/N: HB31C2A1CGS, HB31C3A1CS, HB31C4AS, USB3C2ESAT3
- USB adapter
- Form Factor
- Plug-in card
- PCIe 3.0
- Ports
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
- 10 Gbps
- Built-in SATA power connector, built-in LP4 Molex power connector
- 3 x USB 3.1 Gen 2 - 9 pin USB Type A (external) , 1 x USB 3.1 Gen 2 - 24 pin USB-C (external)
- OS Required
- Limited warranty - 2 years
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.44 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £85.11 |
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.79 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £51.70 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £71.57 |
StarTech.com 7 Port PCIe USB 3.0 Card | In Stock | £61.46 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £29.88 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £26.82 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £29.35 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £9.82 |
StarTech.com USB 3.1 Tool-free Enclosure | In Stock | £25.00 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.51 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £21.00 |
