Your basket is empty
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A)
Quicklinx: 97R1WS00 Mfr#: ST4300U3C3
Ports: 4
  • Windows 8 (32/64 bits)
7 in stock
£42.29 ex VAT
£50.74 inc VAT
Standard delivery Delivered within 3-5 working days
Add 4 USB 3.0 hub ports, plus 3 dedicated USB charging ports (7 total) through a single USB 3.0 host connection. The ST4300U3C3 USB 3.0 Hub enables simultaneous data hub and USB charging functionality by adding three dedicated USB charge ports, as well as four USB 3.0 data ports, for a total of seven ports, all through a single USB 3.0 host connection.
The USB hub ports are compliant with the SuperSpeed USB 3.0 specification, offering data transfer rates up to 5 Gbps, and are backward compatible with USB 2.0 and 1.x specifications.
This AC powered USB hub also integrates 3 dedicated USB charging ports, providing 2 x 1A and 1 x 2A ports, enabling both data hub and USB charging station functionality. Support for USB Battery Charging Specification 1.2 lets you charge most mobile devices, including the Apple iPhone, iPad, Microsoft Surface, Samsung Galaxy Tab and more.
Designed for easy access to the ports when connecting or disconnecting devices, the hub features an upright port orientation, in a compact and durable metal enclosure. For added flexibility, the hub includes a bracket for wall-mounted installations.
StarTech.com 4 Port USB 3.0 Hub w/ 3 Dedicated Charging Ports (2x1A & 1x2A) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
Wall mountable
USB 1.1, USB 2.0, USB 3.0
4.5 cm x 11 cm x 2.4 cm
135 g
Linux Kernel 2.4 or later, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
2 years warranty
Bundled Services
2 years warranty
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Wall mountable
Status Indicators
4 x USB 3.0 - Type A , 3 x USB 2.0 output - Type A
External power adapter
FCC, RoHS
4.5 cm
11 cm
2.4 cm
135 g
5 °C
35 °C
20 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
97R1 StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.18
97R1 StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £7.56
97R1 StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.85
97R1 StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.18
97R1 StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.73
97R1 StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £5.09
97R1 StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £18.62
97R1 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £64.99
97R1 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £71.75
97R1 StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £42.29
Ports: 4
Price Range Ex VAT: 0 - 50
