StarTech.com 4 Port USB 2.0 over Gigabit LAN or Direct Cat5e / Cat6 Ethernet Extender - up to 330 ft
Quicklinx: 9650WS00 Mfr#: USB2G4LEXT2
Type: Extender
Hurry, only 2 left in stock!
£434.00 ex VAT
£520.80 inc VAT
Extend USB 2.0 devices up to 330ft (100m) over a Gigabit Ethernet LAN, or dedicated Cat5e/6 cabling. The USB2G4LEXT2 4-Port USB 2.0 Extender System lets you extend USB devices over a Gigabit Ethernet Local Area Network (LAN), or through dedicated Cat5e/6 cabling up to 330ft (100m).
Connecting over your existing IP LAN avoids the hassle and cost of running new infrastructure cabling and provides an increased and highly scalable overall extension distance. When channeling through multiple switches at 100m intervals, the maximum extension distance resets at each switch location, making it easy to span multiple floors in a home or office setting. For further versatility you can connect the local and remote units via a single Cat5e or better cable.
Unlike 10/100Mbps USB extenders, this versatile USB extender leverages the full data transfer potential of your USB 2.0 peripherals up to 480Mbps, to deliver lag-free performance that enables support for extending isochronous devices such as webcams or microphones.
Compatible with USB 2.0, and 1.1 devices with support for up to 600mA of power per port, the USB over Cat5e extender supports most USB peripherals including flash drives, webcams, keyboards, mice and drive enclosures.
A flexible solution for business or industrial applications, this rugged metal enclosure includes wall-mounting brackets and simple plug-and-play installation with no software or drivers required.
StarTech.com Newer version is USB2G4LEXT2NA - 4 Port USB 2.0 over Gigabit LAN or Direct Cat5e/Cat6 Ethernet Extender System - up to 330 ft (USB2G4LEXT2) - USB extender - USB, USB 2.0
USB extender
Ports Qty
4
External
Data Transfer Rate
480 Mbps
USB, USB 2.0
Max Transfer Distance
100 m
7.6 cm x 10 cm x 2.6 cm
875 g
USB extender
External
Ports Qty
4
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
100 m
1 x USB 2.0 - Type A male , 4 x USB 2.0 - Type A female
FCC, RoHS
External power adapter
7.6 cm
10 cm
2.6 cm
875 g
50 °C
20 - 80%
9650 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £28.67
9650 StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) In Stock £334.38
9650 StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £80.62
9650 StarTech.com 4 Port USB 2.0 over Gigabit LAN or Direct Cat5e / Cat6 Ethernet Extender - up to 330 ft In Stock £434.00
9650 StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) In Stock £148.96
9650 StarTech.com DC Power Adapter - 5V, 3A In Stock £11.75
Type: Extender
Stock Status: In stock
