StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m)
Quicklinx: 7P3RWS00 Mfr#: USB2004EXT2
Type: USB Extender
Interface: USB, USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: External
£334.38 ex VAT
£401.25 inc VAT
Extend four USB 2.0 connections up to 330ft away from the computer over Cat5 or Cat6 cable. The USB2004EXT2 4-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). An included power adapter at remote end provides up to 500 mA of power per port, letting you access and power up to four USB 2.0 devices at remote locations away from the host computer system.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
StarTech.com Newer version is USB2004EXT2NA - USB Over Ethernet Extender - 4 Port - Cat5 or Cat6 - Up to 330' - USB Over CAT5 Extender (USB2004EXT2) - USB extender - USB, USB 2.0
USB extender
Ports Qty
4
External
Data Transfer Rate
480 Mbps
USB, USB 2.0
Max Transfer Distance
100 m
P/N: 35FCREADBK3
USB extender
External
Ports Qty
4
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
100 m
1 x USB 2.0 - Type A male , 4 x USB 2.0 - Type A female
FCC, RoHS
External power adapter
P/N: 35FCREADBK3
7P3R StarTech.com Spare 5V DC UK Power Adapter for SV231USB & SV431USB In Stock £8.83
7P3R StarTech.com 35 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £12.27
7P3R StarTech.com 75 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £24.93
7P3R StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £28.67
7P3R StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) In Stock £334.38
7P3R StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £80.62
7P3R StarTech.com 4 Port USB 2.0 over Gigabit LAN or Direct Cat5e / Cat6 Ethernet Extender - up to 330 ft In Stock £434.00
7P3R StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.31
7P3R StarTech.com 1 Port USB 2.0 Extender Kit In Stock £115.30
Type: USB Extender
Interface: USB
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Stock Status: In stock
