Extend four USB 2.0 connections up to 330ft away from the computer over Cat5 or Cat6 cable. The USB2004EXT2 4-Port USB Extender lets you extend USB 2.0 devices over Cat 5 or better Ethernet cable at distances of up to 330ft (100m). An included power adapter at remote end provides up to 500 mA of power per port, letting you access and power up to four USB 2.0 devices at remote locations away from the host computer system.
This USB extender provides support for data transfer rates of up to 480 Mbps, is Plug-and-Play and hot-swap compatible, and is also backwards compatible with USB 1.x devices.
This versatile USB extender offers a fast, easy, and flexible solution for business or industrial applications with durable metal housing, and an included surface-mounting bracket kit.
- StarTech.com Newer version is USB2004EXT2NA - USB Over Ethernet Extender - 4 Port - Cat5 or Cat6 - Up to 330' - USB Over CAT5 Extender (USB2004EXT2) - USB extender - USB, USB 2.0
- USB extender
- Ports Qty
- 4
- Form Factor
- External
- Data Transfer Rate
- 480 Mbps
- Data Link Protocol
- USB, USB 2.0
- Max Transfer Distance
- 100 m
- 2-year warranty
- Designed For
- P/N: 35FCREADBK3
- USB extender
- Form Factor
- External
- Black
- Ports Qty
- 4
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
- 100 m
- 1 x USB 2.0 - Type A male , 4 x USB 2.0 - Type A female
- FCC, RoHS
- Power Device
- External power adapter
- Limited warranty - 2 years
- Designed For
- P/N: 35FCREADBK3
StarTech.com 6ft High Speed USB 2.0 Cable | In Stock | £3.42 |
StarTech.com Spare 5V DC UK Power Adapter for SV231USB & SV431USB | In Stock | £8.34 |
StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M | In Stock | £3.42 |
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £3.08 |
StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) | In Stock | £332.39 |
StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) | In Stock | £320.07 |
StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) | In Stock | £70.75 |
StarTech.com 1 Port USB 2.0 over Cat5 / Cat6 Ethernet Extender - up to 330ft (100m) | In Stock | £267.01 |
StarTech.com 4 Port USB 2.0 over Gigabit LAN or Direct Cat5e / Cat6 Ethernet Extender - up to 330 ft | In Stock | £419.21 |
