Switch between four triple head computers, while sharing three DVI displays, speakers & mic, USB Keyboard/Mouse, and USB 2.0 peripherals. The SV431TDVIUA 4-Port Triple Monitor DVI USB KVM Switch allows 4 PCs (each with 3 DVI video outputs) to share monitors, 1 microphone and set of speakers, 1 keyboard and 1 mouse, as well as an additional USB 2.0 peripheral such as an external hard drive, thumb drive, printer, or webcam.
The Triple DVI KVM switch enables you to switch back and forth between 4 multi DVI PCs at the touch of a button, while maintaining professional-level video quality on all monitors at resolutions up to 1920x1200. The triple DVI KVM switch also features an integrated USB hub port which allows USB 2.0 peripherals to be shared between attached systems, eliminating duplicate peripheral costs and offering the convenience of sharing stored data between PCs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs must output the same signal type for proper switching. It is recommended, wherever possible, to use DVI-D cables across all PC to KVM and KVM to Console connections.
- StarTech.com 4 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub - Multi Monitor KVM - USB DVI KVM Switch (SV431TDVIUA) - KVM / audio / USB switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- HDCP compliant, built-in 4-port USB 2.0 hub
- Power
- AC 120/230 V
- 21.9 cm x 13 cm x 8.1 cm
- 1.5 kg
- Black
- 3-year warranty
- Designed For
- P/N: SV431RACK, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200
- Status Indicators
- Port status
- 4 x USB 2.0 Type B , 12 x DVI-I , 4 x audio / headphones mini-jack , 4 x microphone input mini-jack , 3 x DVI-I , 4 x USB 2.0 Type A , 1 x audio / headphones mini-jack , 1 x microphone input mini-jack
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- UL, FCC, RoHS
- 21.9 cm
- 13 cm
- 8.1 cm
- 1.5 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 6ft High Speed USB 2.0 Cable | In Stock | £3.18 |
StarTech.com 12 ft PC Speaker Extension Audio Cable | In Stock | £3.46 |
StarTech.com 6 ft DVI-D Dual Link Cable - M/M | In Stock | £6.78 |
StarTech.com 15 ft DVI-D Dual Link Cable - M/M | In Stock | £13.08 |
StarTech.com 10 ft DVI-D Dual Link Cable - M/M | In Stock | £10.72 |
StarTech.com 3 ft DVI-D Dual Link Cable - M/M | In Stock | £4.15 |
StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £7.52 |
StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £19.51 |
StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £27.73 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £192.74 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £135.05 |
StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female | In Stock | £4.87 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £1.36 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £201.08 |
StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub | In Stock | £370.46 |
StarTech.com 2 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £289.96 |
