Control 4 VGA, USB 3.0 equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. The SV431U3A 4-Port USB 3.0 VGA KVM Switch lets you control 4 VGA, USB 3.0-equipped PCs with a single monitor, keyboard, mouse and audio peripheral set. For added convenience, the included KVM cables provide a ready-to-use KVM solution.
This USB 3.0 KVM Switch offers an integrated 2-port hub that supports USB 3.0 data rates up to 5 Gbps, and is backward compatible with USB 2.0 and 1.1/1.0 devices, ensuring flawless performance for your USB peripherals.
Offering support for high resolutions (up to 2048x1536), this 4-port VGA KVM switch has the ability to drive large VGA displays with ease, making it ideal for graphical applications that require high-res video output.
- StarTech.com 4 Port SuperSpeed USB 3.0 VGA KVM Switch with Audio and Cables - KVM switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V
- 10.2 cm x 26.5 cm x 4.5 cm
- 1 kg
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536
- Built-in Devices
- USB 3.0 hub
- Status Indicators
- Port status
- 4 x USB 3.0 Type B , 4 x VGA HD-15 , 4 x audio / headphones mini-jack , 4 x microphone input mini-jack , 2 x USB 3.0 Type A , 1 x VGA HD-15 , 1 x audio / headphones mini-jack , 1 x microphone input mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Cables Included
- 4 x VGA cable , 4 x USB cable , 4 x audio cable
- FCC, RoHS
- 10.2 cm
- 26.5 cm
- 4.5 cm
- 1 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
