StarTech.com 4 Port PCIe USB 3.0 Card
Quicklinx: B9GDWS00 Mfr#: PEXUSB3S42
Type: USB adapter
Compatibility: PC
Interface: PCI Express 2.0 x1
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
34 in stock
£23.65 ex VAT
£28.38 inc VAT
Add four USB 3.0 ports - three external ports and one internal port - to your computer. Here's a cost-effective solution for adding USB 3.0 connectivity to your computer. This 4-port PCIe USB 3.0 card gives you three external ports and one internal port, for the ultimate connection flexibility.
With three external USB 3.0 ports you can connect more devices to your computer. The card provides easy access to commonly-used peripherals such as your tablet and external hard drive. It also features an internal USB port that lets you connect a device such as a flash drive inside your computer case, providing added security and convenience.
USB 3.0 gives you fast access to your files with data transfer rates up to 5 Gbps. Plus it's backward compatible with USB 2.0 and 1.x devices, which eliminates the cost and aggravation of upgrading your existing devices.
Setup is a breeze with native operating system support. The USB 3.0 adapter card automatically installs in Windows.
For convenient installation, this PCI Express USB 3.0 card features a dual-profile design that can be installed in almost any type of computer. It comes equipped with a standard profile bracket and also includes a low-profile bracket for installation in small form-factor/half-height systems.
This high-performance USB 3.0 card is enhanced with UASP support, which can perform ~70% faster read speed and ~40% faster write speed over traditional USB 3.0, when paired with.
StarTech.com 4-port PCI Express USB 3.0 Card - USB adapter
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
Ports
USB 3.0 x 4
1.9 cm x 8.7 cm x 12 cm
59 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
VL805
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Linux 2.6.31 or later, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
USB adapter
PCI Express 2.0 x1
Ports
USB 3.0 x 4
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Built-in SATA power connector, USB Attached SCSI Protocol (UASP)
Processor / Memory
VL805
3 x USB 3.0 - 9 pin USB Type A (external) , 1 x USB 3.0 - 9 pin USB Type A (internal) , 1 - 15 pin Serial ATA power (internal)
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
1.9 cm
8.7 cm
12 cm
59 g
5 °C
50 °C
20 - 80%
B9GD StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £2.95
B9GD StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £23.84
B9GD StarTech.com 10 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £9.33
B9GD StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £57.89
B9GD StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
B9GD StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £63.98
B9GD StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £71.38
B9GD StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £37.70
B9GD StarTech.com 3 Port USB 3.0 Hub plus Combo Fast-Charge Port (2.1A) with Smartphone / Tablet Stand In Stock £16.16
B9GD StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £35.66
B9GD StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £48.20
B9GD StarTech.com 7 Port PCIe USB 3.0 Card In Stock £48.98
B9GD StarTech.com 4 Port PCIe USB 3.0 Card In Stock £25.06
B9GD StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.65
Type: USB adapter
Compatibility: PC
Price Range Ex VAT: 0 - 50
