Add front or rear panel USB 3.0 ports to your computer case using USB 3.0 motherboard-style headers. This PCI Express USB 3.0 card offers a cost-effective upgrade that lets you add four USB 3.0 ports to your computer through a PCIe slot. It offers two external ports plus two internal USB 3.0 headers to help adapt your desktop or server to support a variety of USB 3.0 devices.
With extra motherboard-style USB 3.0 headers you have the flexibility to add more internal USB 3.0 devices to your PC. When your existing headers are occupied, you can connect front panel hubs or card readers using this versatile alternative to costly motherboard and computer upgrades.
For added convenience, the card integrates two external USB 3.0 ports, so you can plug in more devices such as external hard drives or printers.
The USB 3.0 card is easy to install and requires no additional drivers or software in natively supported Windows 8.1 / 8 operating systems. Plus, it features a dual profile design that fits in standard or low-profile cases, so you can rest assured it will fit in your small form-factor system if needed.
Connecting older peripherals isn't a problem either. So, there's no need to purchase new devices since the adapter card is backward compatible with your USB 2.0 and 1.x technology.
This high-performance SuperSpeed USB 3.0 card supports data transfer rates up to 5 Gbps and is enhanced with UASP support, which can perform ~70% faster read speed and 40% faster write speed over traditional USB 3.0, when paired with a UASP-enabled enclosure.
- StarTech.com 4-port PCI Express USB 3.0 card - 2 external, 2 internal - SATA power - USB adapter
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x1
- Ports
- USB 3.0 x 4
- 1.8 cm x 12.2 cm x 9.2 cm
- 55 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0
- Data Transfer Rate
- 5 Gbps
- Processor
- uPD720201 - Renesas
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Linux 2.6.31 or later, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- 2-year warranty
- USB adapter
- Form Factor
- Ports
- USB 3.0 x 4
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0
- 5 Gbps
- Built-in SATA power connector, USB Attached SCSI Protocol (UASP)
Processor / Memory
- Processor
- 2 x USB 3.0 - 9 pin USB Type A (external) , 2 x USB 3.0 - 20 pin USB 3.0 header (internal)
- Included Accessories
- Low-profile bracket
- MTBF
- 1,920,042 hour(s)
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 1.8 cm
- 12.2 cm
- 9.2 cm
- 55 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 20 - 80%
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £2.95 |
StarTech.com 10 ft Black SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £9.33 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £57.89 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £30.85 |
StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power | In Stock | £15.89 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power | In Stock | £18.53 |
StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black | In Stock | £62.49 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power | In Stock | £21.21 |
StarTech.com 3 Port USB 3.0 Hub plus Combo Fast-Charge Port (2.1A) with Smartphone / Tablet Stand | In Stock | £16.16 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £35.66 |
StarTech.com USB 3.0 IDE / SATA Enclosure | In Stock | £23.09 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £47.45 |
StarTech.com 7 Port PCIe USB 3.0 Card | In Stock | £48.98 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £25.06 |
