StarTech.com 4 Port PCI SATA RAID Controller Adapter Card
Customer rating: 4.0* (Write a review)
Quicklinx: 3ZRJWS00 Mfr#: PCISATA4R1
  • Windows 8 (32/64 bits)
The PCISATA4R1 4 Port PCI SATA RAID Controller lets you add four internal SATA 1.0 (1.5 Gbps) ports to your PC through a single PCI expansion slot, while offering support for several RAID modes or a simple JBOD (Just a Bunch of Disks) configuration.
The PCI SATA card provides increased performance and capacity with RAID 0 (Striping), or a redundant copy of your hard drive with RAID 1 (Mirroring). Configuring in RAID 10 (a.k.a. RAID 0+1) lets you leverage both by creating a mirrored copy of your striped disk set. Plus, the SATA RAID card supports RAID 1+S (Mirror + Spare), which uses a third installed drive to automatically replace a failed drive and rebuild the mirrored set - even if it is the boot drive that failed.
For the ability to fit most standard computer cases, the card ships with a standard profile bracket installed and includes a low profile bracket for adapting to slimline or small form factor systems.
While the PCISATA4R1 card supports any size hard drive in JBOD mode, the max supported drive size when in RAID mode is 2 TB (per port).
StarTech.com 4 Port PCI SATA RAID Controller Adapter Card - storage controller (RAID) - SATA 1.5Gb/s - PCI-X
Storage controller (RAID) - plug-in card
Bus Type
PCI-X
SATA 1.5Gb/s
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Hard drive, disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD, RAID 0+1
Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
4.5 cm x 12 cm x 2.2 cm
46 g
P/N: SATSASBAY3BK, ST521PMINT
Host Bus
PCI-X
Storage Controller
SATA 1.5Gb/s
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Channel Qty
4
RAID Level
4 x SATA 1.5Gb/s - SATA (internal)
Compatible Slots
1 x PCI-X
CSA, UL, TUV, CB
Limited warranty - lifetime
4.5 cm
12 cm
2.2 cm
46 g
Customer reviews
Write a review for the StarTech.com 4 Port PCI SATA RAID Controller Adapter Card here!
Might Save Someone Time ...
Reviewed by Alan T. Review Posted 06/04/2007
Not explicitly stated in the DABS summary of this product, I had to go looking on the StarTech site - so just in case someone else passes this way looking for this info .... Yes! you can just run your 4 SATA drives in JBOD mode (i.e. each drive stays separate). With one of these, and four 750GB SATA drives (see such a drive at quick linx 42L2WS) you could build a i/o subsystem that would provide the better part of 3 Terabytes (3000 Gbytes) with very good performance, for around £700!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Does what it says on the box, not the reviews
Reviewed by Anonymous Review Posted 11/12/2007
Great little card, however contrary to some of the reviews, note that it doesn't support RAID 5. I have downloaded the relevant BIOS update and drivers from the Silicon Image website, however windows doesn't allow the install of the drivers (I choose to update the driver for the card, and the RAID5 driver doesn't even appear in the list of options), nor does it allow the update of the card's BIOS through the control panel or the device manager (as described in the SI manual). So while it is an SiI3114 according to device manager, don't buy this expecting to be able to upgrade it to support RAID 5 (at least in hardware). This appears to be different from the dabs value card, which people have said has been successfully updated to support RAID 5.
  • Overall 5*
  • Ease of use 5*
Just works under Ubuntu Gutsy
Reviewed by Jim. Review Posted 12/09/2008
Much easier than I was expecting. I'm running Ubuntu server 7.10 on an ancient 32 bit Athlon, Abit mobo with no SATA support - this card was detected by the kernel at first boot and presented my new drive on /dev/sda. Ten minute job, no pain whatsoever - penguin fans take note.
  • Overall 5*
  • Ease of use 5*
Read all 13 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
