StarTech.com 4 Port PCI RS232 Serial Adapter Card with 16550 UART
Quicklinx: 4JV4WS00 Mfr#: PCI4S550N
Type: Serial adapter
Compatibility: PC
Interface: PCI
  • Windows 8 (32/64 bits)
£34.14 ex VAT
£40.96 inc VAT
Add 4 high-speed RS-232 serial ports to your PC through a PCI expansion slot. The PCI4S550N 4-port PCI Serial card turns an available PCI slot into four RS232 serial ports - a cost-effective solution for connecting any new or old serial peripheral, with support for data transfer rates of up to 115Kbps.
The PCI Serial card is a perfect solution for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more, to your system without having to upgrade your peripheral devices for compatibility with newer standards (e.g. USB).
Saving time and hassle, the Serial PCI card is plug-and-play ready, and can be installed in minutes, supporting Windows 7, Server 2008 R2, Vista, XP, ME, 2000, 98, 95, NT4, 3.1, DOS and Linux operating systems. Plus, the serial card offers IRQ sharing to help ensure stability and consistent performance, guaranteeing convenient, hassle-free connections.
StarTech.com 4 port PCI RS232 Serial Adapter Card with 16550 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI
Ports
RS-232 x 4
11.9 cm x 7.4 cm
RS-232
Data Transfer Rate
921 Kbps
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
Plug-in card
PCI
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
921 Kbps
4 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI
1 x serial panel (internal)
Plug and Play
11.9 cm
7.4 cm
Limited warranty - lifetime
4JV4 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
4JV4 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
4JV4 StarTech.com 2 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART In Stock £23.72
4JV4 StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART In Stock £19.26
4JV4 StarTech.com 4 Port PCI RS232 Serial Adapter Card with 16550 UART In Stock £34.14
4JV4 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.22
4JV4 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.10
Compatibility: PC
Interface: PCI
Price Range Ex VAT: 0 - 50
