StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP
Quicklinx: 8D57WS00 Mfr#: PEXUSB3S4V
Type: USB adapter
Compatibility: PC
Interface: PCI Express x1
More than 50 in stock
£30.85 ex VAT
£37.02 inc VAT
Add 4 external USB 3.0 ports to a low profile or standard computer, through PCI Express. The PEXUSB3S4V PCI Express USB 3.0 Card (with SATA Power) adds 4 external USB 3.0 ports to any PCI Express-enabled computer system with support for data rates up to 5 Gbps, while remaining backward compatible with USB 2.0 / 1.x devices.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
The card uses a "stacked" port layout that places the ports one on top of the other, enabling all four USB 3.0 ports to be external facing, while still allowing the card to fit into a small form factor/low profile computer system using the included low profile bracket.
Plus, with a built-in SATA power connector, each USB port can provide up to 900mA of power to devices that draw power from a host bus connection (500mA for USB 2.0) by connecting to your computer power supply.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 4 Port PCI Express PCIe USB 3.0 Card w/ UASP - SATA Power - USB adapter
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
USB 3.0 x 4
1.9 cm x 7.5 cm x 6.8 cm
45 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
uPD720201 - NEC
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019
P/N: USB3S2ESATA3
USB adapter
Plug-in card
PCI Express x1
Ports
USB 3.0 x 4
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Processor / Memory
uPD720201 - NEC
4 x USB 3.0 - 9 pin USB Type A (external)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
1.9 cm
7.5 cm
6.8 cm
45 g
5 °C
50 °C
20 - 80%
P/N: USB3S2ESATA3
8D57 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £23.84
8D57 StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £5.03
8D57 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £73.16
8D57 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £30.85
Type: USB adapter
Compatibility: PC
Price Range Ex VAT: 0 - 50
