StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485
Quicklinx: 8GTPWS00 Mfr#: PEX4S232485
Type: Serial adapter
Compatibility: PC
Interface: PCI Express x1
Hurry, only 1 left in stock!
£92.53 ex VAT
£111.03 inc VAT
Add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot. The PEX4S232485 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 lets you add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot.
This PCI express serial card is a single card solution that is compatible with nearly any serial communication protocol, supporting RS-232, RS-422, RS-485 2-wire or RS-485 4-wire operating modes.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
StarTech.com 4 Port PCI Express PCIe Serial Combo Card - serial adapter - 4 ports
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
2 cm x 7 cm x 12.5 cm
67.4 g
Ports Qty
4 ports
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
Serial adapter - 4 ports
Plug-in card
PCI Express x1
Wired
2 x RS-232 - 9 pin D-Sub (DB-9) (on cable) , 2 x RS-422/485 - 9 pin D-Sub (DB-9) (on cable)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
2 cm
7 cm
12.5 cm
67.4 g
Limited warranty - lifetime
100 °C
20 - 80%
8GTP StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
8GTP StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
Compatibility: PC
Price Range Ex VAT: 50 - 100
