Add four Gigabit network interfaces to a desktop PC or server with an available PCI Express x4 slot. The ST1000SPEX42 4-port Ethernet Card is an IEEE 802.3/u/ab standards compliant PCIe network adapter, which adds connections to up to four separate high-speed Gigabit networks from a single desktop client, server or workstation.
Suitable for any PCI Express (x4) enabled computer, this Gigabit Ethernet Network Adapter Card offers a practical, cost-effective resource for business, corporate or government environments, with support for high performance 4-channel networking and maximum throughput up to 1000Mbps in each direction (2000 Mbps total) - up to ten times faster than 10/100 Ethernet.
Compatible with a broad range of operating systems, this versatile PCIe Gigabit NIC is suitable for many SMB and Enterprise applications such as virtualized environments that require multiple NICs.
- StarTech.com 4 Port PCI Express Gigabit Ethernet NIC Network Adapter Card - network adapter - PCIe x4 - Gigabit Ethernet x 4
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x4
- PCI Specification Revision
- PCIe 1.1
- Ports
- 10.2 cm x 14 cm x 1.8 cm
- 255 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- TCP/IP, UDP/IP
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Apple OS X 10.8 Mountain Lion, Windows 10 (32/64 bits)
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x4
- PCIe 1.1
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- TCP/IP, UDP/IP
- Status Indicators
- Link OK, link/activity
- Flow control, full duplex capability, auto-sensing per device, VLAN support, WOL, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
- 4 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI Express x4
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 10.2 cm
- 14 cm
- 1.8 cm
- 255 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
