Product
StarTech.com 4 Port PCI Express (PCIe) RS232 Serial Card w/ Power Output and ESD Protection
Quicklinx: 8ZCLWS00 Mfr#: PEX4S553S
Type: Serial adapter
Compatibility: PC
Interface: PCI Express x1
  • Windows 8 (32/64 bits)
£91.62 ex VAT
£109.94 inc VAT
Add four ESD-Protected RS232 ports, with 5V or 12V selectable power output through a PCI Express slot. The PEX4S553S 4-Port PCI Express Serial Card lets you add four ESD-Protected RS232 ports, with 5V or 12V selectable power output through a PCI Express slot.
Ideal for industrial environments, this 4-port serial card offers built-in 15KV ESD-protection which helps prevent damage to connected devices in the event of line surges and electro-static discharge.
Plus, for devices that require additional power, the multi-port serial card also has a jumper-selectable 5V or 12V power output option (pin 9) using either the PCIe bus, or through an SP4 connection to your power supply. For added flexibility, the power output can be enabled or disabled on a per-port basis so you choose which ports supply power.
This versatile RS232 card supports high-speed serial data rates up to 921.6 Kbps, and is compatible with a broad range of operating systems. To maximize installation options, the 4-port card is equipped with a standard profile bracket and includes an optional low profile bracket for installation in small form factor computers. To avoid crowded connections that can occur with fixed/static ports, the card uses a break-out cable which turns a single connector on the card into four flexible RS232 serial ports.
StarTech.com 4 Port PCI Express (PCIe) RS232 Serial Card w/ Power and ESD - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
RS-232 x 4
1.8 cm x 6.6 cm x 8.7 cm
350 g
RS-232
Data Transfer Rate
921.6 Kbps
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
PCI Express x1
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Hardware flow control
2 x RS-232 - 9 pin D-Sub (DB-9)
1 x serial cable (external)
FCC, RoHS
Software Included
Drivers & Utilities
1.8 cm
6.6 cm
8.7 cm
350 g
Limited warranty - lifetime
55 °C
5 - 95%
8ZCL StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.30
8ZCL StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
8ZCL StarTech.com 16in 9 Pin Serial Male to 10 Pin Motherboard Header Panel Mount Cable In Stock £5.12
Compatibility: PC
Price Range Ex VAT: 50 - 100
