Add 4 FireWire ports to a desktop computer through a PCI slot. This 4 Port (3 External/1 Internal) PCI 1394 FireWire Adapter Card lets you connect iPods, MP3 players, portable drives, digital camcorders and more to your desktop computer.
The FireWire adapter card supports hot-swapping, so you'll be able to plug, unplug, and swap your FireWire peripherals with ease.
Plus, the adapter provides both standard profile and low profile/half-height brackets for adapting to slimline or small form factor system applications.
If you require digital video editing software, StarTech.com offers a complete FireWire kit with our PCI1394 4 card. This software is compatible with Windows operating systems only.
- StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal FireWire PCI Card for Laptops (PCI1394MP) - FireWire adapter - PCI - 3 ports
- FireWire adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports Qty
- 3 ports
- Data Link Protocol
- Firewire
- Data Transfer Rate
- 400 Mbps
- System Requirements
- Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows 98/ME, Microsoft Windows XP, Windows 10 (32/64 bits)
- Limited lifetime warranty
- FireWire adapter - 3 ports
- Form Factor
- Plug-in card
- PCI
- Connectivity Technology
- Wired
- IEEE 1394 (FireWire)
- 400 Mbps
- 3 x FireWire - 6 PIN FireWire - male - 3 (external) , 1 x FireWire - 6 PIN FireWire - male - 1 (internal)
- Compatible Slots
- 1 x PCI
- OS Required
- Limited warranty - parts and labour - lifetime - carry-in
StarTech.com 4 port PCI 1394a FireWire Adapter Card - 3 External 1 Internal | In Stock | £19.41 |
StarTech.com 3 Port 2b 1a PCI 1394b FireWire Adapter Card with DV Editing Kit | In Stock | £48.06 |
StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter | In Stock | £55.09 |
StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter | In Stock | £68.92 |
StarTech.com 2 Port PCI Express FireWire Card - 1394a Firewire | In Stock | £26.39 |
